Boring p-lam -- 1 --
5/23
I have a job in which I have to bore 5mm shelf holes in russian birch that has been covered in post form thickness laminate.
I can do it on my 7 spindle pneumatic Blum machine but I can tell it's struggling. The laminate is the problem I think.
Are there better 5mm bits that will fit in my machine, maybe something with a pointed end instead of the ones I have.
5/28 #2: Boring p-lam ...
Use v-point drilling bits, that will help.
5/28 #3: Boring p-lam ...
The bits are called Thru bore. All the usual suspects carry them. Available in two lengths 58 & 70mm, left or right rotation. I'll assume you are line bore drilling for shelf supports. If you are drilling all the way through the thru bore bits are designed for that and will not tear out the back side. The point taper on the Vortex bits I've got is 6mm. Just take that into account, but I doubt it will be a problem.
The dowel bits that you are likely using will sometimes cut a disc of laminate free and then it will spin and prevent the bit from drilling or take a lot of force to over come.
6/1 #4: Boring p-lam ...
Website: http://BayerleinEnterprise.com
You need to replace your bits with "tapered" brad points instead of standard brad points, this will prevent discing, we use tapered brad points on every CNC router in our shop without issues regardless of media being machined.
Kevin
1 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
