Garage doors??
7/18/18
Tom Member
Actually this project is for me!
I would like to build 2 new garage doors. I have built one before and the finish face was rough sawn cedar plywood. The new ones I am considering would be a t&g vertical surrounded by a frame.
The substrate of the door will be a frame work with 1/4" play front & back.
My question is how best to attach the t&g. All exposed material will be cedar. I am thinking of milling the cedar t&g down to 3/8 or 1/2".
Thanks in advance for your help!
7/19/18       #2: Garage doors?? ...
David R Sochar  Member
Overhead or 'carriage house'? Overhead requires different guidelines than side hinged, but no matter what - Why not make your doors frame and panel, like all the other doors out there?
Frame and panel with the ply panel (single, or double with foam in between) is as versatile as ever. Worst comes to worse - the preferred design does not align with the necessary joint - and you will have to have the Main frame there for that part, with the secondary - the visual frame- out front, showing what it looks like.
7/19/18       #3: Garage doors?? ...
And some photos.......
7/20/18       #4: Garage doors?? ...
Tom Member
David,
They will be over head doors.I have found some details on incorporating a drip edge into the field but still not sure of the best way to attach the "field" of t&g to my substrate.
Your advice would be great!
