BauBuche LVL
7/21/18
Gary
The BauBuche Co. is making LVL material made out of Beech. Has anyone used it for engineered door stiles?
Thank you
7/22/18       #2: BauBuche LVL ...
Joe Calhoon
We used some of their 60mm thick material for the core of some 4” thick stair treads. The architect wanted them mitered all the way around and the 60 mm thickness worked out with 4/4 walnut.
It’s nice material but probably more expensive than LVL door cores.
I don’t know if they are made with exterior glue. The sheets are heavy!
View higher quality, full size image (3872 X 2904)
View higher quality, full size image (3790 X 2846)
View higher quality, full size image (2759 X 3680)
7/22/18       #3: BauBuche LVL ...
Patrick
Joe: They do not recomend use for exterior doors ( Which I wouldn't use anyway due my previous experiences with LVL) but only for interior. Cost is not really an issue but I am used to gluing up my own cores out of the same species as the face veneers. Looking to save some production time.
Your thoughts ?
7/22/18       #4: BauBuche LVL ...
Patrick
Joe,
Did you happen to see my post about finding a pivot hinge for radius top doors ? Pivot point is about 10" out from jamb. David made some great observations; would love to get your thoughts as well !
7/22/18       #5: BauBuche LVL ...
door shop guy
I noticed a stack of it at my supplier...the top sheet was curled up like a potato chip.
7/22/18       #6: BauBuche LVL ...
Joe Calhoon
Patrick or Gary..
I think woodweb is playing games with names.
I did see the post about the arch top pivot. Sorry, no help there, have only done square tops with pivots.
My supplier told me the BauBuche behaves like solid wood which it is. They have to turn the top sheets in their stacks just like you would solid edge glued panels.
The material we received was very flat and seemed to stay that way. I still have a wide chunk we cut off and will watch that. I used it for the same reason you are thinking - to save gluing up a solid core for the treads.
It’s basically quartered Euro Beech in the glued up form and according to the wood movement chart here it moves about the same as walnut. So hoping for the best with the treads. They are only 11” wide.
