Curved moulding clamps
2/28/19
Jeremy
Does anyone have experience with the E-Z Arch clamps for gluing up curved casing and molding? How about any of the larger purpose built curve moulding clamps? We do a lot of curved casings and moldings and have a decent system but I feel we could be faster with a better clamp system. Any suggestions? Most of our glue ups are from 3"-6" widths and 4/4 thick. We typically use poly glue for the open time.
3/1/19       #2: Curved moulding clamps ...
Go to http://www.woodweb.com/galleries/shop/posts/209.html
To see the clamp we use. We've had it a lone time, works fine. I responded to a commenter with where we got it.
http://http://www.woodweb.com/galleries/shop/posts/209.html
3/11/19       #3: Curved moulding clamps ...
"LONG time" My computer never learned to type well.
3/17/19       #4: Curved moulding clamps ...
Dan
We have Stack curved millwork clamps , they work well
4/16/19       #5: Curved moulding clamps ...
Christopher Member
Thanks Larry for sharing what works for you. I do believe that a good clamp is worth an investment which is going to last a long time anyway. A simple job could easily be regarded as such a burden without proper tools that are actually easily available in the first place.
4/18/19       #6: Curved moulding clamps ...
If you just need to do an occasional curved casing it is pretty easy just to draw it in CAD and have the router cut the inner & outer form from P bd. . Have the inner form full solid and the outer form relatively flexible and cut with notches for the clamps. The flex of the outer form allows it to conform to slight variations in the build up of thicknesses in the laminations. By routing holes in the inner form for clamps you can just use Pony bar clamps w/o the need to use pipe clamps all the way across. Put down paper on the bench and clamp or screw the inner form to the bench. Takes two people to get the mess clamped up.
