New Motor Bearings : HolzHer 1203
9/16/19
Gary
Can anyone speak from experience as to how difficult it is to remove the motor on a HolzHer 1203 panel saw to replace the bearings ?
Thank you
9/22/19       #2: New Motor Bearings : HolzHer 1203 ...
Larry Schweitzer Member
Don't know on that particular saw . I've replaced a lot of bearings over the years. Pretty simple. Tools usually needed: Bearing separator. I looked them up on Amazon, look at this set: Kauplus 5-ton Bar-Type Puller/Bearing Separator Set, $58. I think it is made in Taiwan so probably OK quality. Always put a drop of oil on the puller lead screw & point. I've got mostly OTC but they are a lot more expensive. It is cheaper to buy the sets than parts. You can use standard grade 8 bolts of any length the project needs if what comes with it doesn't fit. There are a lot of different sizes of separators available. You might as well get a set or 2 of 3 leg pullers while you are equipping yourself. Handy for removing sheaves and the like. Nothing worse than getting something partly disassembled and discovering you need another tool. I'd avoid the Chinese versions because separators and pullers have to take a lot of force. May fail by bending or by shattering, wear your safety glasses. Check the auto parts sores also. Professional level tools can be had at places like Motion Industries (sticker Shock!)
3 Phase motors are really simple, you shouldn't have any problems.
When you take the motor apart pay close attention (or photo) the order. Watch out for the axial spring falling out.
