Copy lathe templates
1/23/20
Does anyone know of any companies that make templates for copy lathes?
I googled it but didn’t find much. I am looking for some bigger diameter legs for tables, about 8 inch diameter at least.
1/24/20       #2: Copy lathe templates ...
Just make one yourself? The dude that does our turning, all he needs is a piece of 1/4" thick whatever for the stylus to ride on. I stayed making the templates on the cnc just so I could save them digitally and not have to save a bunch of wood templates that will likely never get used again.
View higher quality, full size image (4032 X 1960)
1/24/20       #3: Copy lathe templates ...
the google Member
we've made them from acrylic and wood, but the "real" guys are using thin steel cut on a water jet or plasma table. reach out to some metal fab shops to see if they can help.
1/24/20       #4: Copy lathe templates ...
Steel sounds like a requirement on a long run, but how many parts need to be made to justify the expense?
1/27/20       #5: Copy lathe templates ...
I have seen 1/8" to 1/4" aluminum used for templates. Cuts easily on the bandsaw, and files nicely.
2/12/20       #6: Copy lathe templates ...
George Klok Member
Website: http://toolsbros.com
The designs can be made by using the best tools like table saw or any other. For this, you can get help from Toolsbros.
2/12/20       #7: Copy lathe templates ...
My $50 is on the table.
I'm betting no one at Tools Bros can adequately describe what a copy lathe template is.
When an industry is forced to support a vendor network that has less knowledge than the craftsmen, is it doomed to stagnation?
2/12/20       #8: Copy lathe templates ...
Thanks for all the good ideas, I was looking for a template supplier as I figured it would save me time. Years ago an older man said you will never run out of money but you will run out of time. I never seem to have enough time.
I like your ideas and will try cutting some out on the CNC and I have tried cutting one out of aluminium already and it worked quite nicely.
The idea of not having a huge stack of them is also a good idea to consider.
