Power Feeder Lube
5/2/20
Gary
Has anyone had any success lubricating
the hand wheels and acme threads that are used for power feeders in their up & down and in & out adjustments ??
5/2/20       #2: Power Feeder Lube ...
KCR Member
I like using WD-40 for most screw theads in my shop. It has a low viscosity and does not contain any silicone so it won't contaminate wood if it gets on it. Because of the low viscosity, it will evaporate away in time even as it collects dust so it never gums up the screw threads, it just needs to be re-applied as the threads get stiff. On my feeders, I also use it on the large shafts the castings slide on.
5/3/20       #3: Power Feeder Lube ...
MarkB Member
We just wax the hell out of them with a maroon scotch brite. Same as we do for all saw tables, planer beds, fences, router bases, etc.. I crank the column to it's full extent then buff on a good coat of wax on the colum and screw and run it to the other end. Silky smooth.
    Doucet Machinery
