Is it possible to just replace the adjustable wood insert in threshold?
7/27/20
Peter Member
***I want to just replace the adjustable wood filler insert in the sill if at all possible.
Threshold is 36 inches as normal on the french door that opens but as you can see the entire threshold is about 75 inches long.
Screws are 10 inch apart. 3 inch in from the ends.
To put a new one in I would prob have to cut 1/2 of the 75 inch metal threshold from the door that opens at 36 inch point and put in a new one.
BUT I RATHER:
Try to determine who makes it and then if I can remove ONLY the adjustable wood sill filler since it is frozen and the screws are stripped. I would buy a new threshold and my hopes are to take it apart and just replace the adjustable sill.
Do not know who makes this. Wrote a few people with no luck.
Pictures are at my website:
http://www.bebolderhireolder.com/BackDoorThresh/
Thoughts?
Thank you very much, Peter
7/27/20       #2: Is it possible to just replace the ...
Since it's adjustable can you just unscrew it until it disconnects?
8/17/20       #4: Is it possible to just replace the ...
AM
There are t nuts under in the lower part of the threshold and the screws are retained to the adjustable part by pressed on washers. You'll have to loosen the screws somehow to thread a new one in. You should be able to buy one or get a whole new piece and remove the wood part.
    Doucet Machinery
