Soss hinges
9/26/20
Jorge Lasso  Member
Hi everyone,
Do soss hinges work on by fold doors?
9/26/20       #2: Soss hinges ...
TonyF
Jorge Lasso:
Yes, you should be able to open a standard or barrel Soss hinge 180 degrees. Just be sure to follow the manufacturers specifications for number of hinges, weight considerations, clearance and offset, which is different for each hinge model number.
Hope this helps.
TonyF
9/26/20       #3: Soss hinges ...
Jorge Lasso  Member
Thank you Tony!
9/28/20       #4: Soss hinges ...
Yes, they will work just fine. For about a month or two.
Then they will start to sag. I learned to oversize them to slow/prevent the sag.
Larger doors get Tectus hinges now.
    Doucet Machinery
