Subject: Re: Interesting insights that shape lean thinking
7/6/15
Tim Schultz
From Henry Ford's book "Today and Tomorrow'. This book was published in 1926 and was, according to Taichi Ohno, very influential in the shaping of the Toyota system.
"Our own attitude is that we are charged with discovering the best way of doing everything, and that we must regard every process employed in manufacturing as purely experimental. If we reach a stage in production which seems remarkable as compared with what has gone before, then that is just a stage of production and nothing more. It is not and cannot be anything more than that. We know from the changes that have already been brought about that far greater changes are to come, and that therefore we are not performing a single operation as well as it ought to be performed."
7/6/15       #2: Interesting insights that shape lea ...
Gary B.
Tim,
Interesting quote from one of my favorite historical characters. Isn't that the definition of continuous improvement? Have you looked into Deming? I read his stuff before I knew was lean or TOC was....he has some insightful points.
7/6/15       #3: Interesting insights that shape lea ...
Tim Schultz
There are a lot of great nuggets of information in this book.
What I found particularly interesting about this passage had to do with how Ford described current process methodology as being merely experimentation. This kind of feeds into (and possibly informed) Toyota's utilization of the scientific method. At Toyota all current methods are part of a hypothesis and the hypothesis is continually being tested.
This helps to optimize resource utilization. In a typical job shop if someone walks in with a work order whoever is available does it on whatever drill press is available.
At a Toyota factory they start with the assumption that they will need two people for this type of project and three drill presses. If a shortage of capacity shows up in one area they know to revise their hypothesis for that area and know exactly which area has resources to spare. If everybody is free to work however makes sense to them there is more randomness and more of a disconnect between the method and the outcome.
7/6/15       #4: Interesting insights that shape lea ...
Mel
"Insanity: doing the same thing over and over again and expecting different results."
Einstein
Lean beats this out of you. Good today isn't good tomorrow. Good isn't great. Keep going, always.
I could pat myself on the back for what I did at the old shop. But the moment I left it crumbled back to business as usual. That in my mind is no achievement. Not only do you need to make what you want stick, but also, you are never done.
Which is a good thing--minds like exercise as much as muscles :)
