Subject: Re: Wide belt sanders / New or Used
3/10/17
scott b
Is their a source for widebelt machine info, construction and head setups and why?
I know there are alot of used machines out there for reasonable prices but lack the age of the machine or even how to find it and what is longevity of average machine? Also I know the older machines use alot of HP to start up and power consumption is costly. Do the new machines save a great amount of money on the power usage to offset buying a used machine?
We are a small shop looking to run raised panels and other solid wood products, using the machine 1-2 times a week.
Suggestions ???
3/13/17       #2: Wide belt sanders / New or Used ...
Slam Dunk
Scott, My opinion is that there is not much to a widebelt sander. They are basic, and can be rebuilt fairly easily if needed. The thing is, when setting up you raise the platform up to the sanding belt and take light cut. That calibrates it. I personally would not worry about power consumption for a machine that gets used 1 to 2 days a week.
3/13/17       #3: Wide belt sanders / New or Used ...
Kevin Jenness
Some good information here: http://surfprepsanding.com/articles/
3/18/17       #4: Wide belt sanders / New or Used ...
Sanders W/O electronics are simple machines. Most of the wear parts are easily replaced and not all that expensive. Calibrating a machine is also very logical and easy. Worn rubber contact rolls can be resurfaced very simply on the machine, the conveyor belt may need to be replaced and there are suppliers for those. Almost every part on the machine can be sourced from other than the OEMs at much lower cost.
