Subject: Re: Martin Technician
Martin Technician
11/16/17
Read
I recently acquired a 2000 era Martin T72 A. I'm having problems with the display and some of the controls. We can use it manually, but unable to alter the blade height.
Does anyone know of an individual or firm on the Gulf Coast who could take a look?
11/17/17       #2: Martin Technician ...
Mark Elliott Member
Read,
Typically Martin USA can help you figure out what the problem is over the phone. I would suggest to give them a call first.
When my saw started to have issues like that, I do have a Martin also, I was advised to lube the height raising cylinder, all of my problems went away.
Get a lot of lubricant on the shaft and let it float down and you should be good to go, or at least hopefully good to go.
Good luck,
Mark
