New compressor
11/12/15
rich Member
Website: http://www.handmadefurniturecompany.com
We're looking into getting a new compressor. The local compressor guy who has sold us our last two sells Mattei rotary compressors. He has been a good guy in the past which counts for a lot in my book. Problem is I've never heard of this brand and wanted to see if any of you guys have heard of it and if you have any feedback. Thanks.
11/12/15       #2: New compressor ...
agc
I would buy a kaiser rotary screw but if you do buy from the local salesman make sure that his brand is not an Ingersoll rand labeled under another name. Ingersoll rand is notorious for expensive proprietary parts and shady dealing, and if you don't believe me then just do a Google search. I paid around 8k for an Ingersoll rand and of course it capped 9ut just beyond the warranty period despite low hours.
It turned out the circuit board had gone bad and Ingersoll rand refused to sell me just a circuit board as this was sold in a package that also ccontained a new motor. Cost of repair would have been around 7k for a circuit board. What's worse, the reason for their not allowing me to buy strictly a circuit board was that the computer would not let them do that.
11/12/15       #3: New compressor ...
Gary B.
+1 for Kaeser, we've been very happy with both of ours.
11/13/15       #4: New compressor ...
I Googled Mattei: Italian, near Milan. They sell rotary vane compressors so comparing them to Kaeser rotary screws doesn't work.
At least some of the Mattei compressors run oil lubricated and some use bronze bushings for the air end. The only rotary vane units I've owned were Beckers used as vacuum pumps. They were dry vane and worked fine.
I'm pretty sure the Mattei compressor would be a lot cheaper to buy, would require less costly maintenance and be easy to overhaul. Unless you have fairly constant demand, you will need to have air tanks. Look @ Kaeser's web sight for how to configure a complete air system. How many CFM do you need? Do you have a refrigerated drier?
11/13/15       #5: New compressor ...
Hen Bob Member
We have a Atlas Copco, great unit.
