So...Pex or AluPex for airlines?
4/11/16
Pdub
Awhile back, there was a discussion types of pipe to run for airlines. It confirmed my plans to use PEX in an upcoming shop re-arrangement. I have read that you should use the aluminum reinforced PEX for this (AluPEX) but it sounded like plenty of people here used the regular plumbing PEX and it has worked just fine?
4/11/16       #2: So...Pex or AluPex for airlines? ...
The advantage of the Alu is it stays straight so doesn't form dips where condensate can gather. I've heard that some of the synthetic oils used in rotarty screws will degrade the plastic in flexible Pex.
4/11/16       #3: So...Pex or AluPex for airlines? ...
Tom C
Look at what was all written here on 2/13. I left it on over the weekend , just the air,not electric . Lost just 10 lbs air pressure O.A. in 2 days, and that was from a quick change coupling.
Tom C ... The ones with the pics. Would do it all over again this way....
RapidAir
4/11/16       #4: So...Pex or AluPex for airlines? ...
Having worked with led for 20 years I wouldn't hesitate to use it. The problem is if your shop is of any size your mains will exceed the pex in short order. 1" is the most people have access to and when you calculate the loss in the fittings 1" may as well be 3/4 or 1/2. So then your left with alternative mains and PEX drops.
I'd get leary about pex diameters over 1" and 175psi with enough use to generate some heat but your talking high demand.
Anything below that and id run led (non al) all day long. Your gain alone in fitting elimination makes it a win win.
4/11/16       #5: So...Pex or AluPex for airlines? ...
Led × pex. Serves me right for responding from the phone.
4/11/16       #6: So...Pex or AluPex for airlines? ...
Jim
Used rapid air two years ago for shop expansion. Quality materials easy install.
4/21/16       #7: So...Pex or AluPex for airlines? ...
Pdub
Thanks for the responses.
OK, standard PEX it is. We have a 1" black iron line running up the wall and then splitting into 3/4" main line running in a loop around the shop and it seems to be plenty, so we'll go with the same in PEX.
I have zero experience with it, so what type of fitting would you recommend for the system? We keep our tank pressure at 125 going into the pipe.
