Humidification Systems
12/27/16
Jerry Cunningham
I'm looking for suggestions of a humidification system for my shop. It's 5600 sq.ft in PA. On cold days when they gas heat runs all day the humidity level can drop to around 20% which is causing cupping and splitting of our wood.
I think my shop is probably a little too big for portable household units, but maybe not big enough for an industrial system.
Thanks for your help!
Jerry
12/27/16       #2: Humidification Systems ...
RichardP
Hi,
In a 4500 sq.ft. shop located in upstate ny,
we got a humidifier from grainger. It was made to be installed in residential ductwork.
We had no ductwork so built a box with an old furnace blower and ran a water line to the humidifier. No controls, just on full time.
This made a huge difference with minimal cost.
Rich
12/27/16       #3: Humidification Systems ...
JeffD
My shop is only 2400 sf but the ceiling is about 30' at the peak which doesn't help. I bought the largest Sears model which puts out 4+ gallons a day and it still falls short of what I need. So I'd say your right that these won't work for you unless you buy multiple units.
good luck,
JeffD
12/28/16       #4: Humidification Systems ...
Gary
I have been using a couple of Bahnson Type E humidifiers from DnB HumidifierMfg. in 6000 sq. ft. for about six years now. They have been working quite well since then.
About the only thing they require is to be cleaned out a couple times a year. They hang from the ceiling so dust settles in them.
A 1/4" water line is plumbed to them so they fill themselves as needed. I found out about them at the Vegas or Atlanta show.
12/28/16       #5: Humidification Systems ...
Jerry Cunningham
Thanks for the suggestions. I might try 2 of the Home Depot units to start with and maybe I'll get a season out of them. The type E Gary suggested would be perfect, but they are $1500 each.
12/28/16       #6: Humidification Systems ...
Kevin Member
Rich, which unit did you purchase from grainger? This is something I've been struggling with for years.
12/29/16       #7: Humidification Systems ...
RichardP
Kevin,
I am not seeing the same model at graingers. This one is similar.
https://www.sylvane.com/skuttle-86-ud-humidifier.html?s_cid=cse_gpl&gclid=CJnA
oLy6mdECFReewAod6QYBDw
The one we used had disks on an axel instead of a drum. It did get fine dust inside and should have had some kind of filter ahead of it. Hope this helps.
Rich
12/29/16       #8: Humidification Systems ...
Wood Dust
Rich,
Any chance you can share a picture of your setup? I think id like to give that a try
12/29/16       #9: Humidification Systems ...
RichardP
Wood dust,
Closed that shop 20 years ago. Not sure if camera was invented then. Just build a box with legs so the humidifier can hang below.
Inside the box a furnace blower, the ones with internal motor work best. On the intake side use a furnace filter to reduce dust buildup. 1/4" water line and you are good to go. Hope this helps.
Rich
1/1/17       #10: Humidification Systems ...
Gene Wengert-Wood Doc
At 70F, the amount of moisture required to increase the humidity from 20% RH to 38% RH is around 1 pint per 3000 cubic feet of air. Of course, air leaks to the outside or dust systems that vent to the outside will greatly increase this.
You do not want to go above 38% RH, as this will be much more humid that a customer's home or office, so the wood will shrink when the customer gets it...high humidity just pushes the problem to the customer.
Also, note that dry wood is quire strong, so observed cracking is often a small unnoticed crack that grows rather than creation of new cracks.
1/2/18       #11: Humidification Systems ...
the google
jerry,
what did you go with and what have been your results?
after almost 10 years without an humidity control in the winter, we're running into issues with too dry air. it normally isn't this cold for prolonged periods for us, but cracks are multiplying quickly.
