Bolt
7/28/18
Joseph Eultgen
Website: http://eultgenwoodworking.com
Can anyone tell me the correct name if these and possibly where to get them.
Thank you
Joseph
View higher quality, full size image (720 X 1280)
7/28/18       #2: Bolt ...
Harold
Sex bolts. Google it and available all over country. I get them from broward bolt here in south Florida.
7/29/18       #3: Bolt ...
RichardP
Not sex bolts!
The sex bolt consists of a female (internally) threaded barrel (nut) and a male (externally) threaded screw. Both the barrel and screw have heads designed to clamp (bind) material between the head of the barrel and the head of the screw, or to bridge the gap between two parts.
They are wood screws.
7/29/18       #4: Bolt ...
David B  Member
Website: http://beaconcustomwoodwork.com/
Flat head wood screw with hex or allen drive
7/29/18       #5: Bolt ...
They look like Confirmats to me.
confirmats
7/29/18       #6: Bolt ...
Charles Member
I started to say Confirmats earlier today, but these have a pointed tip. The Confirmats that I use have a blunt tip and require the use of a 2-step drill bit. The screws in the photo do have a solid shank near the top that is thicker than the shank inside the threads.
Maybe it is a different brand of Confirmat that does have a sharp tip???
Confirmats do come in a variety of types and sizes of heads. Some are 4mm hex. Some are #3 Phillips. Some have larger diameter heads. The heads in the photo appear to have a tapered section, almost like a bugle-head.
7/29/18       #7: Bolt ...
Confirmats come either way
7/29/18       #8: Bolt ...
Charles Member
Thanks, Pat. :-)
7/30/18       #9: Bolt ...
MarkB Member
There is no scale in the OP's image but I had seen some screws from a company in AU a while back that look very similar to these. Anzor was the name. Pulled the link out of my bookmarks and at least they, are calling them coach screws. No idea why.
http://www.anzor.com.au/stainless-steel-socket-head-screws/countersunk-coa
chscrews/product
7/30/18       #10: Bolt ...
Bill  Member
Website: canadianacabinets.com
Richelieu and Hafele both have several types, All require stepped drill bit
Great fastener. Strong.
View larger image
https://www.richelieu.com/documents/docsGr/119/297/7/1192977/1410510_hd.jpg
7/31/18       #11: Bolt ...
MarkB Member
Sorry but the OP's screw looks nothing like a confirmat to me. It has a clearly countersunk head where as a confirmat doesnt and has more of a wafer head to apply clamping force in-line with the screw and reduce the wedge force of a typical countersunk head.
It looks like a typical asian inspired furniture screw. Basically a socket head wood screw that doesnt require a specific bore.
