Subject: Re: Quick conectors to air tools leaking air all the time
5/18/15
We buy new quick connector fittings 1/4" for the air tools from both Home Depot and Menards. It seems like monthly they're always failing in the sense of they either leak right away or when you move the air sander, nail gun, etc, it will leak then. We have tried both kinds. Where you pull the sleeve back to engage or you push it in and it locks around it.
Does anyone make a better quality one that will take a heck of a lot longer to fail?
Links anyone?
Thx!
5/18/15       #2: Quick conectors to air tools leakin ...
Jim Clark
I switched to the 3/8" ones, they connect
to the std 1/4" air tool threads and do much better. My HVLP guns spray better and my
impact wrenches are more powerful now.
Home Depot sells them in a kit for around
$10.00. They're much more durable.
5/18/15       #3: Quick conectors to air tools leakin ...
I use Milton V high flow
5/18/15       #4: Quick conectors to air tools leakin ...
Bill,
What are those and where do u get it? Links?
5/18/15       #5: Quick conectors to air tools leakin ...
The ones you are buying are probably Chinese stuff. Go to an industrial supply house and buy some good ones.
5/18/15       #6: Quick conectors to air tools leakin ...
You can get the Milton V high flow at Northern Tool, lots of other places too. Cheapest price I've found was Amazon.
5/19/15       #7: Quick conectors to air tools leakin ...
Pete Anderson
Website: http://petesfloors.wordpress.com
The air tools rely on "O" rings for the seal.
Do you think if you used some o-ring grease on the fittings there would be less leakage?
I don't remember to always grease the fittings, but they may hold a seal better. They probably all have grease when they are new.
5/19/15       #8: Quick conectors to air tools leakin ...
Bill,
Whats the difference between the home depot special and the Milton V?
5/19/15       #9: Quick conectors to air tools leakin ...
Been there done that. Go to McMaster and get some quality brass connectors. When they do need to me replaced the knurled part of the brass are worn smooth.
5/19/15       #10: Quick conectors to air tools leakin ...
todd71
Fosters manufacturing has the best couplers I've found. Got them form the local "Hose power" store. Great product.
Foster Manufacturing - Springfield, Mo.
5/19/15       #11: Quick conectors to air tools leakin ...
"Whats the difference between the home depot special and the Milton V?"
The V high flow have a much bigger bore than the standard coupler, and IMO Milton are much higher quality than the ones I've bought at HD or NAPA. I haven't had any leaks.
- See more at: http://www.woodweb.com/cgi-bin/forums/cabinetmaking.pl?read=779410#sthash.uk79JFLP
.dpuf
5/19/15       #12: Quick conectors to air tools leakin ...
door shop guy
Miltons only for me. I believe i use the M style. Never a problem. I also highly recomend Dynabrade in line blow guns and swivel connectors. Friends dont let friends buy tools at Homedepot or Menards!
