Subject: Re: Which sprayers are you guys using?
6/2/15
Dan Mueller Member
With all of the changing technology, I'm torn on which direction to headtowards on my search for a new sprayer. I currently use an older Graco Monarch air assisted airless with a Graco contractor gunwith a 2 finger trigger and a Rac 5 413 tip. I like the single hose and the ease of setup and go, but different sales reps guarantee key that I'll be happier and use less material with a 2 line system and adjustable gun. I'm mostly afraid of change. Any advice and or advice?
6/2/15       #2: Which sprayers are you guys using? ...
al
Dan, I have a similar situation. I bought a titan airless ed655 which has a diaphragm pump. It shoots a flawless finish. It says in manual to only use water base or oil base products. I emailed
Titan and was told it would be okay to use solvent conversion varnish. I used it a couple weeks
ago with CV and it came out great. I think I may have damaged a seal using a solvent finish but am not 100% sure it was because of the CV or not. So I would like to keep this unit for water base
and get another unit for solvent. No air bubbles in water base with this unit and I only need to use
a 15' hose. I have been told with a piston pump airless you need a longer hose or you will get a miss every now and then. Airless gun and tips are pretty affordable compared to what I'm hearing
about AAA guns and tips.
How long of hose do you use on your current set up?
6/2/15       #3: Which sprayers are you guys using? ...
Dan Mueller Member
I use a 25' hose with my pump now. I also have a 50' that I use on occasion. Honestly, I've never even seen a shorter hose. That would be nice. I spray mostly precat lacquer and post cat CV. It's been a good pump, but if I can save a few $$ plus then I could use the old pump for sanding sealer and a new one for topcoat. Also saving some $$
6/3/15       #4: Which sprayers are you guys using? ...
al
I bought 15' hose on internet from a company called Gleem paint. It actually cost more than the 25' because they don't sell a lot of the 15. I think it was $50 but I buy the tips and filters from
them and they are much less expensive than the paint stores. I find with the 15' hose there
is less material waste when cleaning up. From what I have researched the CAT pump and
gun uses a 25' hose but is has an id of 1/8" compared to 1/4" on airless and from my calculations 25' of 1/8 has less volume than 15' of 1/4".
6/10/15       #5: Which sprayers are you guys using? ...
JeffD
I use the Cat pump with Bobcat gun and it does a fantastic job. I think they run 2 different types of hoses, smaller diameter for solvents and larger for wb? I don't know the diameter hose I'm running off the top of my head, but there's no problem getting enough finish out of it.
One thing to check if your spraying post cat is the seal. Mine went after less than 2 years spraying! Rep came out and replaced with a newer style that can be tightened over time to account for wear.
good luck,
JeffD
6/10/15       #6: Which sprayers are you guys using? ...
I have a Binks AAA aa1500 with cart mount for sale. I bought a brand new Kremlin, so im looking to sell my unit. I did a Seller Refurbished unit. I replaced every gasket, seal and packing that comes with the two manufacturers re build kit. I love my AAA unit. The Binks one sprays great, i just wanted to upgrade.
All i spray are alcohol based dyes, PU top coat and paint, and typ. Pre-cat's
