Subject: Re: Parts rack/cart
Parts rack/cart
8/16/15
Brian Member
We build standard Euro cabinets. After milling the parts via CNC we band, scrape, and clean all parts. The parts are then carried or carted over to our parts bin. They are then separated by denomination. I.E. upper and lower end panels, tops, bottoms, stringers etc.
My question is, does anybody have or know of a good mobile cart to stack everything on at my bander? I could then roll it to my boxing area? I'm thinking of something that is open on either side so that part can just be pushed through to the boxer. The rack we have has dramatically cut time since we were no longer having to find the left that matched with the right. Now that is being done before hand. I'm just looking to cut a little more waste.
Thank you in advance,
Brian
8/16/15       #2: Parts rack/cart ...
They make racks for this but to tell the truth you get a lot more parts on a cart if you just stack them on flat.
Something to consider is reducing your batch size, so there are fewer parts to sort.
8/16/15       #3: Parts rack/cart ...
Brian Member
Batch size reduction has been integral to getting better flow and having a production ready for our end user in a faster manner. We used to cut a whole job, maybe 6-10 rooms all at one time. Now we only cut 2-3 rooms at a time. We have found that stacking parts on end (book style) has been best for us when sorting. I may need to consider shrinking the batch again though. Serious food for thought.
Mainly I am looking to save another set of actions, taking out of the bander, to a cart, to a bench, scrape clean, to a cart, to the sorting rack. I was hoping to go right from the bander to scrape/clean to the rack.
Waste waste waste. Gotta get rid of it.
8/17/15       #4: Parts rack/cart ...
cabmaker
What you might want to consider is storing cabinet sides horizontally and having the vertical racks for the horizontal parts.
For the most part your cabinet sides are probably common in dimension and they are going to need to have hardware inserted anyway. Keeping these parts flat will help with installing the slides etc and might even allow for this activity to start happening while you are sorting the vertical parts.
Something that might be worth considering is to map out the processes that are subsequent to cut out. Sequences and priorities might also have an impact. If you have a formal ordering for which cabinets are going to be assembled first this might influence what kind of storage capacity you need and how much capacity you need. If you can choreograph the shop so that the guys are building parts in the order they get pulled to the assembly bench you will have fewer puddles of parts to manage.
