Subject: Re: SPAX - Using Torx screws long term
8/18/15
scott Member
Anybody use SPAX screws from Germany? Feedback?
Also, what about Torx head screws to prevent cam-out - Do they really work long-term or do the tips snap off easier or wear out so that that they slip like philips?
thinking to go to Torx to forever stripped screw heads. (I'm aware of the issues of someone having difficulty removing screws later but we mostly use screws in permanent places)
8/18/15       #2: SPAX - Using Torx screws long term ...
Buy a box of GRK too and compare them.
8/22/15       #3: SPAX - Using Torx screws long term ...
Harold
Website: http://Morantz cabinets.com
we have used square head screws for 35 years and the only time we have issues is when the bits have worn down. Harold.
8/23/15       #4: SPAX - Using Torx screws long term ...
scott Member
Has anyone actually used SPAX brand? I would like feedback on this specific brand from any users.
(thanks for the other posts; appreciated)
8/23/15       #5: SPAX - Using Torx screws long term ...
Mark Elliott Member
Scott,
I use Spax all the time.
I know they cost more but I feel they're worth the extra money. They don't break the way case hardened screws do.
Mark
8/24/15       #6: SPAX - Using Torx screws long term ...
scott Member
Mark,
Thanks for the reply. Are the Spax you use Torx, square or other? do you use both bugle head and pan-head of Spax?
Do you use the screws with the serrated threads?
do you always drill pilot holes in hardwood when using Spax?
8/25/15       #7: SPAX - Using Torx screws long term ...
Mark Elliott Member
Scott,
I use the combo head mainly, but that's what I have easy access to.
I always drill pilot holes. Even with the serrated threads I don't buy the hype you don't need them.
The only advantage of the serrated threads is the size of pilot hole is not as critical, a smaller one is ok, but I always drill one.
Mark
