Subject: Re: TORX Screw heads in woodwork production
8/18/15
scott Member
Does anyone have experience regarding Torx head vs Philips vs Square vs combo drive screws in the wood factory / woodshop? Do Torx head screws really prevent cam-out LONG TERM? - Do they really work long-term OR do the tips snap off easier or wear out so that that they slip like philips after they've been used for a while?
Goal is screw installation without slipping and stripping heads, without snapping off screw heads, and without snapping off screw tips.
Thinking to go to Torx to forever avoid stripped screw heads. (I'm aware of the issues of someone having difficulty removing screws later but we mostly use screws in permanent places)
sorry my last post got sidetracked onto the brand of screw - I am asking for EXPERIENCE of people who have USED Torx and square drive and have some advice.
8/18/15       #2: TORX Screw heads in woodwork produc ...
Chris
Torx. Using square again now just because my suppliers don't stock all sizes and I haven't put in the effort to try to find the torn screws alsehere in all sizes. Only thing that isn't great is the itty bitty tiny torx...the tips can twist into a spiral or if you slip, put a hole in your hand. For general assembly they are great great great (25,s I think they are)
8/18/15       #3: TORX Screw heads in woodwork produc ...
Chris
are)
8/19/15       #4: TORX Screw heads in woodwork produc ...
scott Member
Thanks Chris, how small diameter was so small they had problems? #6, #8, #10 all ok? 3.5mm, 5mm? (not sure if you use metric or old English..,)
8/19/15       #5: TORX Screw heads in woodwork produc ...
JeffM
Just buy good quality driver bits and you'll be fine. The cheaper ones will break especially with impacts. I use torx for box construction, square for face frames.
Throw out all of your phillips junk!
Wouldn't it be nice if we only had one choice and it was a good one?? I've never understood why we need to have 6 - 10 choices in screw head types.
8/19/15       #6: TORX Screw heads in woodwork produc ...
Jim Member
I use all square drive so we don't have to change bits on the drivers. Have not experienced cam out with the square drive.
Curious as why Torx is preferred over square.
8/19/15       #7: TORX Screw heads in woodwork produc ...
scott Member
Thanks for the info. If you all vote for me, when i become world dictator i will banish everything except Torx. Continued slot head producers will get life in prison, philips 20 years hard labor, Square drive and quadrex will get off with a warning ;-)
8/19/15       #8: TORX Screw heads in woodwork produc ...
Jeff M
Jim.
For what it's worth, I think Square is probably just as good as torx in the hands of a professional. Beginners will still let square heads slip once in a while. Torx will break before they slip.
8/19/15       #9: TORX Screw heads in woodwork produc ...
scott Member
Jeff, why is it that you use Torx for box construction, but square for face frames? why not Torx for all? Do you find that Torx are more likely to break than square? We used all square in my factory in California and were happy with them, but did find they would slip after a while - especially as the tips wore down. Are you saying the tips dont wear down and slip for Torx?
8/19/15       #10: TORX Screw heads in woodwork produc ...
chris
#10 spiraled every once in a GREEAT while..hardly worth mentioning. I used to work in Germany...Torx is standard in construction and cabinetmaking with the exception of every now and again "Wurth" proprietary heads (very similar to torx)..Torx was better. For some reason pozi drive was standard for hardware. If you find a good source for the Torx, Id love to know. BTW, in my experience square drive screws get stuck when you remove a screw or are done driving it JUST often enough to become annoying (especially whenone hand is driving the screw and the other holding something)
My 2
8/19/15       #11: TORX Screw heads in woodwork produc ...
Jeff M
I use square for FF because that is really all that is available in panhead ff screws. Eventually the squares will round a bit allowing some slippage.
I have never had slippage with torx. They would be my first choice and square 2nd.
8/20/15       #12: TORX Screw heads in woodwork produc ...
Square was invented first. It does not camout.
Philips was designed 2nd so that it did camout. On assembly lines the installers would snap the fasteners before camout, so Mr. Philips the engineer designed a head that camsout on purpose.
Torx was designed to optimize everything. They were for pneumatic installation of large fasteners with high torque loads in the auto industry.
Square do not camout if you use good screws with good bits. The heat treated tipped bits last for years.
8/20/15       #13: TORX Screw heads in woodwork produc ...
Duster
We use mostly #2 square drives for just about everything. However, I have had a hard time lately finding good driver bits. Any recommendations for for a brand or supplier of hardened bits?
8/29/15       #14: TORX Screw heads in woodwork produc ...
Denny J
We use square for pocket screws but torx for all assembly fasteners and pozi for hardware.
Switching to torx was one of the best assembly improvements I have made.
8/31/15       #15: TORX Screw heads in woodwork produc ...
Jeff M
Duster...Kreg makes great bits.
