Subject: Re: supermax brush sanders
8/24/15
guy
Looking to buy a supermax brush sander for doors wondering if anyone uses one would like to know if it will put a stain ready finish from my drum sander with a 180 grit on the drum or does it need to be sanded to remove the cross grain lines and how does it do when staining will it be ready to stain with no face touch ups
thanks for any info
http://www.supermaxtools.com/products-sanders/243649-superbrush/
8/24/15       #2: supermax brush sanders ...
Karl E Brogger
My very small exposure to brush sanders, I wasn't very impressed. A shop I worked at had one on the orbital Timesaver for breaking edges. It didn't work very well. The other experience was setup for sanding profiles on trim, it didn't do a great job either.
You're going to still have cross grain scratches if it's rotating against the grain.
What's the application or goal?
8/25/15       #3: supermax brush sanders ...
Rick L  Member
Have a lot of experience with brush sanders. Mostly we use them to texture new antique wood. I think you're expecting too much of it. Send them a sample piece for you to look to see if it does what you want .
8/25/15       #4: supermax brush sanders ...
guy
thanks for the info i will probably pass on buying one
8/25/15       #5: supermax brush sanders ...
Rick L  Member
Talk to them about what you want do and send them sample to see for yourself.
9/27/15       #6: supermax brush sanders ...
Adam West  Member
I have extensive experience with brush sanding. No brush sander, no matter how large or elaborate, will replace cross grain sanding after a wide belt machine.
There is a heck of a lot more to brush sanding cabinet doors successfully than a single straight brush. It can be done but it will require multiple passes and even then the product will not be as well sanded as can be achieved by a proper brush sanding machine.
I would save your money and get your wide belt working the best it can for you through comprehension and training with as little hand sanding as possible. Then we can worry about the next step.
