Subject: Re: Construction Bore
Construction Bore
10/9/15
Stewart Member
Hi Everyone,
As we are progressing with the learning curve of our flat table cnc, I am beginning to see the value of moving toward doweling our boxes together since my finished ends are integrated (not a separate applied piece). I'm thinking about adding a horizontal bore machine (not cnc at this point) but know nothing about them. I know accuracy is a huge issue with doweling - either you are right on or not - there's no fudging. What machines do you guys use and are you pleased with the accuracy you are getting out of them? It is extremely important to me that I achieve flush faces and edges. My budget is about 7K right now but if I can't find anything built well enough in that price range, I will wait until I can afford something better. Thanks for your help!
10/9/15       #2: Construction Bore ...
Zack
Unless you are buying used, I would stay away from anything in the 7k price range. 7k is on the lower end of construction boring machines and if you're worried about accuracy, you wont find it there.
If you are buying used, I would go with a Gannomat. They are on the upper end of machines and they last a long time. I know plenty of people that have Gannomat's and they are very happy with the durability and accuracy. The only problem with buying them used is that they are hard to find because people tend to keep a hold of them for a long time.
I would suggest a lease to buy option on a new machine though, if you can. If you have the demand, you'll find that doweling will really speed up production for you and you'll pay off that leased machine quickly. Plus, if you don't like that machine ultimately, you wont be stuck with it.
Whatever you do though, don't go cheap. Remember, this machine is making you money so durability and accuracy are key. If you get into production with a cheap machine you are rolling the dice. It might work great, but it has an equal chance to break down on you and if it does, it will take time to fix it. It costs less to spend a couple thousand more on a good machine then to have a bad one break and not be able to get jobs out the door for days.
Good luck and I hope you find what you're looking for.
10/9/15       #3: Construction Bore ...
Andrew J. Coholic  Member
Website: http://www.joecoholiccustomfurniture.com
I recently added a Maggi system 23 boring machine this year (horizontal and vertical) mainly to put together melamine boxes with dowels, but have done enough other work (mitred doors, other framing, drawer boxes) to see it will certainly be a decent machine and serve my relatively small shop well.
It was on special for $8K Canadian. I looked at other similar machine from $8K to $10K - all seem to have similar options, but various depth adjustments, # of hold down clamps, etc.
So far alignment is right on the money (as usual, it is only as good as your setup, and also how accurately your stock is cut/prepared.)
