Subject: Re: Servicing Brandt Gluepot
12/17/15
Bernie
I have a KD55 and am hoping to do some preventative maintenance on the gluepot. I had it rebuilt 2 years ago, but am not looking to got that route again.
I'm planning on replacing the heaters, as they have been sporadically replaced over the years, and I'd just as soon start with a fresh set. I'll also do a full cleaning.
What other parts should I consider replacing? The machine sees moderate daily use.
Thanks.
12/17/15       #2: Servicing Brandt Gluepot ...
cabinetmaker
Watlo anti seize for the elements. sealed bearings if you are taking it out and going to the trouble of new elements
12/18/15       #3: Servicing Brandt Gluepot ...
Bernie
How difficult is it to replace the bearings?
12/19/15       #4: Servicing Brandt Gluepot ...
Bernie
Anyone?
12/19/15       #5: Servicing Brandt Gluepot ...
Jr Lee  Member
Website: http://www.leeconsultants.info
Bernie,
A couple of months ago I had my gluepot, KD54, totally apart and replaced the bearings. Mine were totally consumed with glue(bad seals in bearing) so it was a struggle to get them out because of the glue. Replacement would have been much easier if the glue had not got into the area and bound everything up. If you have a pretty good grasp of mechanical things you should be able to do the job. You will probably need a puller to get the bearings off the shaft. Also clean the port that is used to apply grease at the side of the gluepot to ensure the grease will flow into the bearing area. Also there is a small hole in the bottom of the pot that allows the grease get to the bearings that may need to be cleaned. Small drill bit and long punch. You will need Hi-temp grease, it is much cheaper at Mcmaster Carr. Pack the bearings before you install them. Stiles techs told me to apply grease after each use of the bander. And it was already said to use anti-sieze on the heating elements. Good luck
Jr
12/20/15       #6: Servicing Brandt Gluepot ...
Bernie
Thanks very much
12/20/15       #7: Servicing Brandt Gluepot ...
cabinetmaker
I don't have a Brandt, but on my machine the bearings attach to the glue reservoir in a metal housing that is almost impossible to get the bearings out of. I would look at your parts list, call Stlies and see if something is offered as a rebuild kit and if sealed bearing are available. A little more expnsive, but in the area of frustration releif , a no brainer
When I clean the pot before dis-assembly I saturated rags with lacquer thinner and place them in the bowl and put the thing in a bag, sealing it for a few hours and the excess glue generaly wipes right out.
12/20/15       #8: Servicing Brandt Gluepot ...
Jr Lee  Member
I found that Stile does not offer a rebuild kit. You need to order individual parts. Service manual from Stiles is several hundred dollars. If you supply me your email address I can supply you with a parts list for the KD54 which should be pretty close to the KD55. You probably already know that the bearings are in a small sub assembly in the gluepot and it will require some carefull study to determine how to remove the bearings. If I remember your original question. If you replace the bearings note how the old ones come out relative to the seals.
the new bearings I received were sealed only on one side which I thought was unusual.
jr
12/21/15       #9: Servicing Brandt Gluepot ...
Bernie
Thanks very much. I think I have the schematic, but if I can't put my hands on it, I'll check back in.
