Subject: Re: Appliances close to the floor
12/20/15
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
I have a request to build a cabinet in a kitchen in which it's a double oven and a micro with trim kit above that. This places the bottom oven of the double oven basically just above the toe kick height. Any issues with this? Typically the specs call for a minimum distance from the floor to the bottom of the double oven appliance.
12/20/15       #2: Appliances close to the floor ...
cabinetmaker
yes, the manufacturer generally requires about 18" or so. Get a copy of the spec from the manufacturers website and you might want to call the city or county you live in and see if it is an issue also. You can deflect some of the work on the customer to check with a real estate agent because it may lead to a failed home inspection. (By of course someone that really doesn't know what they are talking about)
