Subject: Re: Shelf Construction
Shelf Construction
12/21/15
Larry K. Member
1 1/2" Thick x 24" deep x 5ft. wide span/open shelving.
In general: I have always used slab shelving and inserted a metal support to the leading edge to stiffen it up.
The idea of a honeycomb center, 1/8" mdf shins and plam over that has been brought up.
Any pros & cons on this? Thanks
12/26/15       #2: Shelf Construction ...
JP Member
Torsion box shelves. They are strong.
MDF? I'm not sure about that. I always use plywood for the grid inside. I figure the plys add strength.
5ft is a long span. How much weight are you talking? Angle or square tubing would be the strongest.
12/27/15       #3: Shelf Construction ...
Mike Fuson
I believe I would stick with the slab.
