Subject: Re: Roo Glue Alternative - Bonding to Pre-fin plywood.
2/16/16
Cabmaker
Does anybody know of a panel adhesive that can be squeezed out of a caulking gun but can also stick to the finish on a pre-finished maple plyood?
We often have to bond an applied wood panel to a pre finish side. The usual protocol is to scuff sand the pre-fin plywood then yellow glue the panel directly to the scuffed up pre-fin. Sometimes there are small shims put into place if we need to make up some distance.
Managing the small shims is a struggle, particularly if they are 2mm thick or less. I was thinking maybe we could squeeze out a bid of panel adhesive and this could self-level as pressure was applied to the panel. Any area that one time needed a small shim could now be spanned with the more flexible bead of glue.
Any suggestions for a type of glue that might bond directly to the pre fin plywood without also adding the scuff sand process.
2/16/16       #2: Roo Glue Alternative - Bonding to P ...
Dan/drbwoodworks
Loctite clear power grab heavy duty. I was very pleased how well it stuck . The local hardware store or lumberyard should have it .
2/16/16       #3: Roo Glue Alternative - Bonding to P ...
Dan
Silicone or PL
2/16/16       #4: Roo Glue Alternative - Bonding to P ...
Cabmaker
What is PL?
2/16/16       #5: Roo Glue Alternative - Bonding to P ...
Dan
PL is an adhesive in a tube. PL premium is what I'd use. Sticks to anything
2/17/16       #6: Roo Glue Alternative - Bonding to P ...
Mike Member
I agree with the PL but i would also suggest the PL polyurethane.
Something that the marine industry uses is a product called 5200 this will hold a 2 ton lead keel to fiberglass and everything else we ever used it on.
2/18/16       #7: Roo Glue Alternative - Bonding to P ...
We use PL400. It is a construction adhesive. If you need to take it apart later, figure on destroying it. Don't use Liquid Nails, not nearly as good. Do scuff sand.
