Subject: Re: Brad nailer is blowing wind
2/25/16
Puzzleman Member
I have Ridgid brad nailer that just all of sudden went pop. Then it started blowing air out the back. Have now had this happen to a second one.
Any ideas on the problem and solution?
2/25/16       #2: Brad nailer is blowing wind ...
Mitch Suber  Member
Website: subercustomshutters.com
I have had a similar problem with the staplers we use. The best I remember on one it was an o-ring that was bad, on top the piston/striker. The air that should have been lifting the striker back up was blowing by and out the exhaust port. On mine, I could remove the top cap by taking out 4 screws. By carefully removing the cap, I could lift everything out and see my problem. On that gun, I was able to order the part and replace it. The shipping may be more than the part, you might want to order a few extra O-rings and get more for your buck. If that is the problem.
2/26/16       #3: Brad nailer is blowing wind ...
Puzzleman Member
Thanks. That is the problem.
Really appreciate your help.
2/29/16       #4: Brad nailer is blowing wind ...
Max Neu
Try this,
Unplug the gun from the air hose,hold the trigger in and press the nose against a piece of wood,then plug the air in to the gun without releasing the trigger or nose from the piece of wood.I have to do that to my grex guns occasionally to get them unstuck.
3/6/16       #5: Brad nailer is blowing wind ...
jake
Rebuild kits for these sometimes cost more than a factory reconditioned nailer. By the time you add your labor into the mix, might as well chuck it in the trash.
