Subject: Re: frameless upper corner cabinet
3/5/16
jbiddle Member
I'm new to building frameless cabinet and I have two upper corner cabinets to build. I know these aren't correct since there's nothing for the door to close against. I could use some guidance.
View higher quality, full size image (3840 X 2016)
3/5/16       #2: frameless upper corner cabinet ...
door shop guy
I think it depends on what you want your reveals to be. Once you determine that, then you will know how to do your bulkheads and what hinges to use.
Im oldschool and i used to just draw it out on a piece of cardboard before i built anything.
3/5/16       #3: frameless upper corner cabinet ...
Harry DeVrieze  Member
There are Euro hinges specifically made for what your are doing. Check with your supplier.
Regards
3/5/16       #4: frameless upper corner cabinet ...
Jim Herron
Actually those are correct but you need to lose the filler between the angle cabinet and the one on the left to maintain your reveals between the doors. Use full overlay hinges on the left wall cabinet and 45degree on the angled cab- the angled door closes against the top and bottom shelf only.
Make the angled door 1/8"- 3/16" narrower than the angled opening between the case sides.
If the right hand side is finished, use an applied end that projects 3/4- 13/16" past the case.
If it has cabinets on the right treat it the same as the left.
Hope that helps. Salice has a good guide to show hinge applications and reveals.
3/5/16       #5: frameless upper corner cabinet ...
Leo G
With the Blum 45 degree hinge you need to keep the door 5/16" away from the carcass and not clip the gables at 45 degrees. The top view pic shows how I've built many frameless corners.
View higher quality, full size image (1121 X 857)
3/6/16       #6: frameless upper corner cabinet ...
jbiddle Member
Does this mean that the width of the door should match the door opening?
3/6/16       #7: frameless upper corner cabinet ...
Leo G
It does look that way. But I'm not sure.
Corner to corner from the opposite doors minus your spacing margin is a more accurate measurement.
