Subject: Re: Router Bit Supplier Problem
5/14/16
Mike Member
We have a router bit problem. We were using the Her-Saf Screw Type Helix Router Bits. We were buying the 15/32", and using it to dado undersized plywood. Unfortunatly, they are no longer in business and I need a new supplier. I can find every other size we use except for the 15/32. Any help would be greatly appreciated. Thanks MIKE
5/15/16       #2: Router Bit Supplier Problem ...
Dan/drbwoodworks
Contact ctsaw.com . They should be able to help you
5/16/16       #3: Router Bit Supplier Problem ...
Chuck Hicks  Member
We have them on the shelf. Call 877-465-7012 for more info (SEH13469)
5/16/16       #4: Router Bit Supplier Problem ...
Richard Member
FWIW I found this posting on the "Talk ShopBot Forum"
Good news about the inserts from Her-Saf. They are sending their machine to Edge of Arlington in Arlington, TX. Phone # for Edge of Arlington is 1-817-461-7171. Called to verify. Talked with John. The sale just happened yesterday so it may be couple of months before they learn the new equipment but are planning to make the inserts. They are also looking for suppliers for the bodies of the cutters. They are expecting some inventory but don't know what may be included.
Just a satisfied user of the Her-Saf tooling, needing inserts.
5/16/16       #5: Router Bit Supplier Problem ...
Mike Member
Dan, I didn't see it in the catalog. I've checked with Whiteside, and they don't have it. I will have to call to find out for sure. I am glad to see they sell VELEPEC. I like their solid surface bits.
Chuck, I do see you have it. I would like to see it in the shorter depth. So when we go from one size to another, we wouldn't have to adjust the depth.
Richard, I'll try to keep up on it. We just need them sooner than later.
Thanks for the quick replys. Greatly appreciated. MIKE
5/17/16       #6: Router Bit Supplier Problem ...
Adam Spees
15/32 = 11.9mm
Buy a 12mm from most router bit companies.
