Subject: Re: RE: Grizzly Drum Sander-- Rollers
5/28/16
Tommy
We recently purchased a used Grizzly G1079 Drum Sander.
When researching how a sanding belt is installed on this sander, we found that a 45-degree cut has to be made on a 5-inch sanding roll, and repeatedly rolled on to cover the entire 24-inch wide roller.
I was wondering if there is any other alternative to this method. Are there any 24-inch wide sanding belts that we could be directly installed, instead of going through this process every time we want to change the grit on the rollers?
5/28/16       #2: RE: Grizzly Drum Sander-- Rollers ...
John Member
Drum sanders use sanding strips; it's the nature of the beast. Changing the sanding strip on my Delta is a two minute job. The clips that hold the strip at both ends are spring loaded and very easy to use. I've never used the Grizzly but I've heard the clips on it can be a pain. The alternative to using plain sanding strips and the clips is to use a H&L system. Grizzly appears to sell one for your machine. (See the link below.) If that's not a direct fit you can buy aftermarket ones.
John
Grizzly - for your machine
5/28/16       #3: RE: Grizzly Drum Sander-- Rollers ...
Even if they were available, a 24" wide belt would require a linear seam/clamp similar to what you see on flooring sanders. This type of clamp is like driving a tire with a flat spot. Every time it comes around it leaves a bump.
The reason the drum sander is spiral wound is so that the drum acts like a single sheet of paper.
We have a dual drum sander with hook and loop and it is relatively fast to change. Nowhere near as fast as a widebelt but reasonably fast. The issues of hook and loop on the drum are a bit similar to on an RO. The hook and loop creates a bit of a cushion behind the paper and can leave you less than perfectly flat on certain woods where it will cut a little bit more of the soft grain than the hard. Its very minimal though and easily cut out with RO with PSA paper.
Widebelt is the best option but we are where we are at times.
