Subject: Re: built in medicine cabinet
6/6/16
jacob
Hello.
Trying to design a built in medicine cabinet:
Where it goes in a cut out in the sheetrock- there are plenty made out of aluminum frames where there is a lip all around which is pretty thin.
How can i achieve this is wood : after all if use concealed frameless hinges the max overlay can be 3/4" so i cannot very well add a lip .
Any ideas or am i barking up the wrong tree?
6/6/16       #2: built in medicine cabinet ...
Mike Member
What if you cut the sheetrock accurately and trimmed the rock with the plastic or metal channel they sell for capping sheetrock (its a 3 sided piece that slides over the edge ) and then build the box with a rabbet around the edge for the sheetrock. You will have to install it one piece at a time to get it in but then the 3/4 overlay will cover the rock.
If you can have it proud of the wall then make a groove and have the sheetrock insert into that.
6/6/16       #3: built in medicine cabinet ...
dustmaker1 Member
After switching to frameless cabinets years ago this was the only type I still made a face frame for. I believe we used compact Blum hinges with plant on face frame mounts.
Another type of cabinet we make sometimes is a pass through blood draw, simple box with full overlay door, cut hole accurately, install box slightly proud and caulk in.
We have also made box out of 1/2" material with 1/4 x 1/4 added to one edge then run through bander with 1/4" temporary piece, miter fold out of this profile.
Paul R
6/6/16       #4: built in medicine cabinet ...
Sam Jackson
Check out Blum inset hinges. We make med cabs all the time with a frame and inset hinge. Just add a shelf at the bottom to act as door stop. Euro hinges of most manufacturers come in full, 3/4, 1/2 and inset overlay. Hope that helps!
6/7/16       #5: built in medicine cabinet ...
jacob
thanks guys.
i realized i posted on wrong forum...
what i was really looking for was the 1/4 by 1/4 idea . with 1/2" sides therefore having a full overlay frameless cabinet.
need to make quite a few of these and this leaves the contractor 1/2" height and width play for his cut out.
ideally i would like more but cant find a hinge that can do more than 3/4" full overlay unless i use salice 40mm cup hinge for thick doors ..but dont want to.
6/8/16       #6: built in medicine cabinet ...
Duster
My Blum rep just showed me a new hinge that can do up to a 1.5" overlay, and opens 92 degrees. It uses all regular mounting plates, you change the overlay by increasing the distance of the boring from the edge of the door. You might want to check those out.
6/8/16       #7: built in medicine cabinet ...
Jacob
interesting.
thanks. do you have a part number ?
6/8/16       #8: built in medicine cabinet ...
Duster
the hinge is a 125 degree zero protrusion with a restrictor that reduces the opening angle to 92 degrees. part # 71T750D.
6/8/16       #9: built in medicine cabinet ...
Jacob
thanks. real interesting hinge.
