Subject: Re: cutting starboard
cutting starboard
6/8/16
Henry Member
we occasionally get calls for cabinets made from starboard which is basically plastic. cuts with regular tools but the one huge issue is when it comes time to do the hinge boring in the doors, the 35mm bit on the blum machine cuts long strips that wind up around the shaft. even if we peck up and down it still happens, so after every door we need to cut the plastic away. does any one know of a 35mm bit that might cut plastic without creating long continuous strings?
thank you
6/8/16       #2: cutting starboard ...
Jared
Do you have a CNC? If so, have it bore out the hinge cups with an o-flute upshear bit and avoid the 35mm altogether.
6/8/16       #3: cutting starboard ...
Roman
https://www.youtube.com/watch?v=8Xoj1OXPqj4
You Tube video
6/8/16       #4: cutting starboard ...
Andrew J. Coholic  Member
Website: http://www.joecoholiccustomfurniture.com
You need a Forstner bit with some grooves cut into the cutting edge (which are also staggered a bit to not leave ridges). Acts to break up the chips.
Or, as previously stated, router the hinge holes which machining on the CNC.
6/9/16       #5: cutting starboard ...
Henry Member
I am couple months from our first cnc, so much to get in place before it lands, but in the mean time I may try Andrews idea. The video Roman posted was very helpful too since I was wondering how a cnc would handle the chips and it seemed to be no problem at all. and the 17 minutes for a sheet was incredible.
6/9/16       #6: cutting starboard ...
this is the style I was referring to, although you have to find a 35mm one, or modify an existing bit/cutter.
http://www.leevalley.com/en/Wood/page.aspx?p=62137&cat=1,180,42
240
Lee Valley link
6/10/16       #7: cutting starboard ...
Roby Bass
I have had a couple jobs where starboard would of worked great. All my suppliers here did not have any info on starboard. Do you have a good place to order starboard from the internet? Live in South Dakota.
6/14/16       #8: cutting starboard ...
Rick W
We are in the Midwest, but we order our Starboard from Piedmont Plastics out of Tennessee.
They have branches throughout the USA.
Rick W
6/14/16       #9: cutting starboard ...
Roby Bass
Thanks for the lead. I will check them out. Not sure how I pasted someone else's website. Sorry Andrew J Coholic.
