Subject: Re: White Glue
White Glue
6/17/16
Bernie
Looking for a suggestions for a white glue with similar characteristics/strength as yellow glue. We use miterfold drawers (partical board wrapped in white vinyl) and glue the joints with Titebond. We try to wipe off any squeeze out at the joints, but invariably do end up with some residual glue (yellow) after the fact, which stands out against the white interiors. Thinking that white glue residue would be less apparent. Suggestions?
6/17/16       #2: White Glue ...
Hen Bob Member
Shouldn't the yellow glue pop right off the white vinyl? Try "RooClear" Glue
6/17/16       #3: White Glue ...
Ken Member
This subject has been hammered to death many times. Search the knowledge base. The yellow you see is dye. Most of the mfgs. have PVAs that are white, as well as extra thick, extra thin, fast set, etc. I would call CP Adhesives http://www.cpadhesives.com/ and talk to someone there. Don't get stuck thinking what's on the store shelf is what you have to choose from, go to the mfg.
6/17/16       #4: White Glue ...
duster
Titebond makes a white glue that's very similar to their yellow glue. Your supplier should be able to get it for you.
