Subject: Re: dust collector woes
dust collector woes
7/6/16
the google
we just installed a 2005 disa s-750 (7.5 hp) and it is giving us problems. the machine was purchased from a one man shop and appears to be in very good condition.
we installed it and it ran perfectly for about a week. starting last week, and continuing this week, it will cut off after 10 sec to 30 minutes of running. it won't come back on immediately, and can take several minutes before it will start again.
any thoughts? the starter amperage is set correctly (adjusted by us shortly after we powered it up). the motor is hotter to the touch the closer you get to the fan but nothing outside of the normal.
7/6/16       #2: dust collector woes ...
cabinetmaker
Turn off the power and open up connection boxes to the machine and @ the motor and make sure all leads are tight and there is no chance of them working themselves loose
Check the voltage coming in to the machine is it correct and are the trim pots on the starter correctly adjusted ?
7/6/16       #3: dust collector woes ...
the google
all has already been done. starter amps are correctly adjusted.
it has been working intermittently today. i was out of the shop last week but it is highly unlikely than anything wiring/connection related changed while i was gone.
7/6/16       #4: dust collector woes ...
cabinetmaker
open the fan and check it is tight don't forget the rim speed of a loose item can cause an overheat situation and cause extreme vibration making the most complicated of diagnosis actually pretty simple
Also, check to make sure the overloads are properly seated
7/7/16       #5: dust collector woes ...
Jared
Single phase or 3 phase?
7/7/16       #6: dust collector woes ...
Bruce H
Starting with the obvious, what wire size is feeding the motor, what amp draw is the motor requiring and, how much wire is feeding the motor (length) from the main panel? I'd check all the wire connections in the circuit and the breaker at the panel. Using an amp meter, how much is the motor drawing? Compare this to what is on the name plate. These might not be the issue but it is a place to start.
7/7/16       #7: dust collector woes ...
Do you have to press the OL reset after it stops? Then either the OL's are bad or the motor is drawing too many amps. I hope it is 3 phase. Amps go up as voltage goes down. Long small wire causes voltage drop! Is your power the correct voltage for the motor? If the OL settings were set for 240 V and you are running on over 10% lower you will need to reset the OL amperage to account for the low voltage. Get the ammeter on each of the wires and make sure they are all reading correctly. Could it be too much bearing drag as they heat? Use your IR temp gage to check them. It also will check to see if there is a bad connection or overloaded wire.
