Subject: Re: Heavy vanity question
7/12/16
Marcia Member
Thank you so much for your reply.
When you say support brackets on the side of the studs, do you mean like this?
Do you think it is not strong enough to use L brackets secured on the surface of the studs (a little bit like in the third photo)?
View higher quality, full size image (564 X 317)
View higher quality, full size image (450 X 298)
View higher quality, full size image (4064 X 2704)
3/17/17       #2: Heavy vanity question ...
Marsay Member
Thank you for all your help.
I ended up making the vanity out of poplar. Installer (not me) created a wood piece that goes across the back of the vanity so the vanity can rest on that back piece. Three metal legs were also added at the front.
View higher quality, full size image (1296 X 967)
