Subject: Re: Inset hinge
Inset hinge
9/12/16
Bob
I'm working on a frameless cabinet that has a door recessed 1/2" from the front edge. Is anyone aware of a hinge that would work in this situation??
9/12/16       #2: Inset hinge ...
EDDIE KITSON
Use a regular inset hinge just set back 1/2" or add a vertical piece inside and just use regular overlay hinges. Adjusting the vertical part as needed.
9/12/16       #3: Inset hinge ...
Leo G
Standard inset setup. Inset hinge bracket and 1/2 overlay hinge. And just set it back an extra 1/2". Use a 110 degree hing so it doesn't hit when fully open. You might have to put a restrictor in there to stop it at 86 degrees.
I did one similar. It was recessed 7/16"
View larger image
