Subject: Re: Edgebanding and frameless cabinets
11/3/16
Lee
Website: http://www,legacywoodworking.net
I have a question regarding frameless cabinets. I'm doing a job now that has 3 different species of wood, plus some painted cabinets. All finished end panels and such will be installed on site. My question is, when you edgeband, do you match the finished exterior wood, or match your cabinets interior? I use prefinished maple for my boxes and was thinking of just using prefinished maple edgebanding for the boxes. In the past, I've matched the exterior wood, but was thinking that for ease of banding I'd do them all the same so as not to mix parts.
11/3/16       #2: Edgebanding and frameless cabinets ...
Leo G
I do exterior match.
11/3/16       #3: Edgebanding and frameless cabinets ...
If you are doing an attached end panel, isn't the whole face showing? And you want to have a 3/4" wide natural maple stripe on a painted end panel? I'd match exterior.
11/3/16       #4: Edgebanding and frameless cabinets ...
Lee
The Face of the box will be behind the doors. The only thing seen on the exterior is the doors/drawer fronts, and the end panels with a solid piece of wood to look like a post.
11/3/16       #5: Edgebanding and frameless cabinets ...
JeffD
I've tried matching the exterior the hard way, by staining and finishing/painting, but it's far too time consuming. I personally would not want the banding to match the interior if it were different than the exterior, but it has been done. I think it was Thomasville that had a line of Euro cabinets done this way.....I did not like the look myself.
Nowadays I use PVC banding. I find a color/woodgrain that matches my doors as closely as possible and all is good.
good luck,
jeffD
11/4/16       #7: Edgebanding and frameless cabinets ...
Hen Bob Member
We match the exterior, As far as finishing goes we stack up 4-6 sides at once and spray. Clamp all stretchers together and spray as one piece. It actually goes pretty quick
11/4/16       #8: Edgebanding and frameless cabinets ...
Lee
Thanks guys. Up until now, everything has been a natural wood, so it was easy to find a matching band. I like the pvc idea.
11/4/16       #9: Edgebanding and frameless cabinets ...
jake mcgovern Member
Website: http://paramountwoodworking.com
we do a lot of euro boxes here and what we do is buy the matching raw wood and wrap it around some 4' long 12 round sono tubes. sand stain spray to match exterior then we roll it back up and run it on the edge bander. much easier then staining and spraying a bunch of random part sizes after its applied.
11/4/16       #10: Edgebanding and frameless cabinets ...
Tom C
We usually match exterior.
We try to do 1 MM when we can,
Like Henbob,we stack & clamp,but higher, run wrap & pack around the clamps for overspray, (dozen dedicated clamps)
and wide paper tape on some areas.
For all our white painted stuff, we use 1MM PVC. We have a couple colors that match most paints, Frosty, Designer,Ant. Wh.,Alabaster.....
Took 5 minutes to edge the boxes in the pic... bypass finishing to assembly
Greys,we use folkstone,fog,,,,
Custom colors ,Stack & we paint same CV.
All interior shelves I use 1 MM maple PVC
We have now a Brandt Ambition With Premill, very clean edges, Happy so far.
Been doing it this way for 20 years..
The only time I got a complaint was when I used prefin cherry on the boxes on a stained Budget cherry job. Go figure ....?
View higher quality, full size image (1080 X 1920)
11/6/16       #11: Edgebanding and frameless cabinets ...
aj
Tom C.. How do you go about getting the thicker end panel look? Is that 2 panels glued together then banded?
11/7/16       #12: Edgebanding and frameless cabinets ...
Tom C
The tall one is a 3/4" Door panel with a 3/4" MDF bottom section biscuted on & pocket screwed.
Joint is 1/8" Below the top that we stained to match floor.
The panel is then built-up on back side with 3" rip of MDF, Then 1/4" Solid stock glued on. Hoffman lip planed,sanded, 1/16" RO.
The 2 end panels we finished in shop, Conestoga finished all the other .
Crown & Base site painter.
