Subject: Re: Recently someone posted about edge molding
11/10/16
Recently someone posted about edge molding that would work for tables so that the edge does not get chipped up from chairs running into the edge.
I can't seem to locate the post. Have you seen this post?
11/10/16       #2: Recently someone posted about edge ...
Mark V.
Pat,
Is this what you are looking for?
Mark
Chipped laminate edge
11/10/16       #3: Recently someone posted about edge ...
Perfect, thanks a bunch Mark
11/16/16       #4: Recently someone posted about edge ...
Has anyone used this material on a radius?
11/18/16       #5: Recently someone posted about edge ...
Peter Rawlings
Pat, I've run it on large radii. Think bow front on a narrow peninsula top at bar height. I imagine something like a 10' radius. It certainly won't bend around a small radius like 6" or 12".
As I recall, there are two types of Solid Surface material...polyester and acrylic resin, I think. One bends better than the other, call Loti for more info, nice folks and very helpful.
11/18/16       #6: Recently someone posted about edge ...
Thanks Peter
They sent me out a sample that was 6" long but it barely flexes. They said it would be no problem on the large radius that I need.
But since I need quite a bit of it I wanted to check other's experience.
I have need some that is 2 7/8" for the edge of a conference table.
The tongued material that is 1 1/2" looks fantastic.
I was a little concerned on the wider stuff as there is no tongue, so you have to clamp it precisely within a few thousandths.
