Subject: Re: Laser on a slider for straight lining
11/29/16
laser for straight line ripping on a slider.
Hi
Am interested in a laser and wondering how useful you feel it has been on the saw.
Is there a cheap but accurate laser available.
Barry
11/29/16       #2: Laser on a slider for straight lini ...
Im not sure Id understand why? On even a 10' slider you can easily align a board in a single pass by eye and feel. If your straightlining so much material that your looking for efficiency the answer would seem to me to look into an SLR or have your material SLR 1E before it land to you.
Straight lining on the slider is fine for a few odd boards here and there but not much more than that.
11/29/16       #3: Laser on a slider for straight lini ...
Ken Member
I'm with you on this Barry. I just ripped a small batch of material and while I did do it by eye I was thinking a simple cheap laser would have made it easier. And in my shop a SLR wouldn't make sense. Carter Products make a couple of line lasers but they're >1K. I have a cheap level that has a laser on one end. I'm going to pull the laser out and fab a mounting bracket.
11/30/16       #4: Laser on a slider for straight lini ...
Barry Golash
No room for a SLR. This video explains the need and use of a laser on a slider.https://www.youtube.com/watch?v=5cxmtbKLG38
11/30/16       #5: Laser on a slider for straight lini ...
Sure, concept was clear. There are many inexpensive lasers <$50 even that would do it.
We do quite a bit of straight lining on the slider and glue line rips but have never had the need. I suppose if your trying to take off a half a blade thickness it would be handy. I'd think mounting one to an over-arm guard would be more convenient than a celing mount for alignment and on/off unless you found one with a remote.
Looks like you have a solution.
