Subject: Re: Rollout shelf clearance
12/8/16
Adam B Member
Looking for ideas/suggestions on how you handle sizing your roll out shelves. We are a face frame shop,and we have always set up our roll out shelves to be adjustable up and down within an opening. We do this by either drilling 5mm holes the entire length of the partitions, or by incorporating some type of pilaster system (currently using tenn-tex) when hinge clearance is needed. I have however shied away from combing a pilaster on the hinge side with vertical holes on the partition of the non hinge side. For those familiar with tenn-tex pilaster, you know that there is a special connector that connects the roll out slide to the pilaster and that connector would not work with 5mm holes drilled in a partition. This forces the pilasters to be used on both sides and reduces the width of each roll out by at least 1 1/4" unnecessarily on the non hinge side.
With all of that said what suggestions do you have to keep roll outs adjustable, but but yet clear door hinges?
12/8/16       #2: Rollout shelf clearance ...
Bruce H
I am a euro shop and use spacers provided by Blum. Hinges clear behind the guide and can be adjusted in the line drill system.Might work for FF?
12/10/16       #3: Rollout shelf clearance ...
Joe
Have you considered using a a KV0255 standard in conjunction with a KV1303 stand off? I've seen it done that way as well as simply shelf mounting it and using hold down clip to secure the adjustable shelf.
