Subject: Re: Faceframe rail on a shaper
12/10/16
Joe
Website: http://joescustomcabinetry.com
I have decided to change up how we process our frame stock. Currently we bring it in at 13/16 straighlined on one long. Here's our process:
1 Sand stock down to 3/4"
2 Power feed to 3/32 over desired width
3 2-3 passes over thickness planner until we are at desired thickness
4. Off to frame cut station
Here's issue. This works really well for most of our wood but maple and cherry end up with too much chip out on the edges. I have tried running the edges through the widebelt but it has been clumsey at best. I require extremely precise thickness for my rail width and my sander doesn't seem to be exactly capable of what I'm asking. Then there's the edges that seem to get rounded over slightly leading to poor frame joints.
Here's my proposed new schedule.
1. Sand to thickness
2. Rip to 3/32+
3. Cut frame stock to length
4. Clean first edge against shaper fence
5. Size width against second fence opposite the standard fence
That's the plan. Here is why I think it will work better for us. I can pre-stock all my rail as sanded and ripped. I never had luck stocking sized rail as it changes in size over time based on humidity.
If we use a shelix head we should have much less tear out and chipping in challenging woods. The tear out on the back side of the cut on the miter saw would be milled out on the shaper.
Now my two questions are this. Any feedback on this approach? Secondly I recall seeing a shaper fence system that was designed to do this sort of thing years ago and I'm trying to track it down. Basically a fixed is added parallel to the standard fence. Different widths of HDPE are added against the secondary to adjust widths. I like the idea of just purchasing a system if I can find it rather than re-inventing the wheel. Is anyone familiar with this set up?
12/10/16       #2: Faceframe rail on a shaper ...
KR
I never machine to finished width until I cut to finished length. Then I machine all edges of stiles and rails on an outboard fence on the shaper setup with a digital ruler. I start all frame material 1/4" oversize in the rough. Machine off 1/8" from the convex edge (also called the crown). reset measurement to final frame width, turn parts to second edge and machine edge to final frame width. This process is fast and does a perfect job straightening any stock under around 36" with a fence about 42" long. Use a longer fence for longer stock.
12/10/16       #3: Faceframe rail on a shaper ...
Jim Clark
After I rip them 1/16 larger
I run all my rails and stiles across my
router table. It makes all exactly parallel
and exactly the same width.
View higher quality, full size image (2048 X 1360)
12/11/16       #4: Faceframe rail on a shaper ...
door shop guy
If you get the Wynmatic system...i recomend do not get his fence and just make your own out of a piece of 1/2" baltic birch and a piece of laminate. I had to send his fence back because his plastic facing is crooked and not consistent and not even square to the table. Other then that his other shaper fence parts are good. In my opinion.
12/11/16       #5: Faceframe rail on a shaper ...
cabmaker
Our process to do this is similar to Jim Clark does it though we use a shaper instead of a router.
The shaper has a fixed fence at the far end of the table. From this fixed position we have a library of shims that reduce the part to a final, repetitive size. This is done with a power feeder.
We also have a dedicated 15 inch wide planer with spiral head. The cutting head is in a fixed position at 22mm thickness. We use a similar set of shim/sleds to control thickness in the other direction. Our glass stops, for example, are always a consistent thickness.
We usually mill a bit of extra stock in case that defects of anticipated defects etc. up.Being able to produce repetitive dimensions (with minimal skill and set up time) allows us to use fall down from previous jobs and/or bank extra stock for subsequent projects.
12/11/16       #6: Faceframe rail on a shaper ...
Barry Golash
Hi
I saw this post and thought of the jig I made for the shaper. I use it to size stiles and rails. It has a tape measure on the jig so I can easily get the size I need
View higher quality, full size image (600 X 450)
12/11/16       #7: Faceframe rail on a shaper ...
I was taught to never run a piece of stock between a fence and a bit. Just asking for an accident if the stock binds or kicks back. How do those systems handle stock that isn't straight?
12/11/16       #8: Faceframe rail on a shaper ...
jbdyer
I use a system similar to what Barry is using. Have been doing this for about 20 years and never had a problem, you can use a feather board if you think kickback might be a problem. I usually rip to +3/16" , run both sides on shaper to +/- .005 (I check this with a micrometer(a $40 tool)), cut to length, assemble, then sand completed face frame to .750, if the frame is wider than my wide belt, then I sand first then assemble.
12/11/16       #9: Faceframe rail on a shaper ...
door shop guy
I think Weaver and Aigner both have system tools to do this as well. I have found that you need pressure to push the stock against the outboard fence or the cutters could pull the stock into the cutter more. You guys will laugh at me but i use ball catches in my wood fences to do this.
Not needed for climb cutting and i have climb cut a lot as well. I use a 4 wheel powerfeed.
12/12/16       #10: Faceframe rail on a shaper ...
Barry Golash
Hi
Never had a kick back. I always use a power feeder. Its hard for a piece of wood to kick with downward pressure from a power feeder.
That`s why its used to climb cut.
BW Barry
12/12/16       #11: Faceframe rail on a shaper ...
Rich,
I think you were taught not to freehand a piece between the cutter and an outboard fence. It is a standard procedure used by most people who run shapers. It is typically done with a power feed that provides pressure against the fence and table. In my mind its perfectly safe it setup correctly. I'm still not a fan of climb cutting.
12/14/16       #12: Faceframe rail on a shaper ...
KR
Barry, Like your fixture! Is this available on the market or did you build this?
12/14/16       #13: Faceframe rail on a shaper ...
Barry Golash
Hi
I was building a 3 axis cnc at the time and was looking for parts on eBay. I found this linear motion assembly and could not
pass it up. Even though I had no intended use for it. Then it came to me to use this assembly as a outboard fence. Its worked just fine.
I had a digital readout attached to it but it was a pain to calibrate it when the batteries died. So now it has a tape and pointer.
The doors always seem to come out the correct size so its precise enough.
12/14/16       #14: Faceframe rail on a shaper ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
I've never had a kick-back problem either.
But I always straighten one side on the
jointer first and take off less than 1/16"
per pass on my router.
Lately I find using a Freud Glue Line Rip
blade on my table saw also gets it really
straight to begin with.
