Subject: Re: Pre finishing panels
2/10/17
Daniel Member
Hello all. New member here.
I'm replaceing some panels in already existing cabinet doors. All are currently unfinished and I'm curious. In regards to potential wood movement. Does it make more sense to refinish the panels before in stalling them? My fear is that if I finish everything together, and the panel shrinks(it's solid wood) then there will be a crack in the finish where the panel meets the frame or a discolored line. Or both. However, my dead line is fast approaching and I'd rather hand them off to the finisher as a complete unit and not have to install them after finishing. They're going in from the back with mullions holding them in place.
Thanks in advance for any help! I've been reading you guys advice for a long time now and I greatly appreciate all of the wisdom that is found on this forum.
2/11/17       #2: Pre finishing panels ...
Dan cook
You can just pressing the edges of the panels before assembly and then assemble, stain the whole door and finish the completed assembly.
