Subject: Re: Vacuum pump repair
Vacuum pump repair
3/2/17
Brent Member
Has anyone replaced the vanes in a vacuum pump? I have a 1997 VTLF 250 Becker 25 hp pump and I called Becker and veins are almost $1400. I can find them for less than $250 elsewhere but I have never tried to replace them.
3/3/17       #2: Vacuum pump repair ...
Dan cook
I have a similar Becker pump. They are quite easy to change. They just slide out and slide new ones in. Make sure the bevel is in the same directions as the ones you take out. They are horribly expensive and they break ke glass if you drop them, so be careful in handling. They are very fragile.
3/3/17       #3: Vacuum pump repair ...
Where did you find them for less?
3/3/17       #4: Vacuum pump repair ...
Brent Member
They are aftermarket vanes and they are for sale on ebay.
3/3/17       #5: Vacuum pump repair ...
How long did the first set last?
3/3/17       #6: Vacuum pump repair ...
Mine lasted about 10-12 years in moderate to heavy use.
3/3/17       #7: Vacuum pump repair ...
My concern would be that the $250 vanes would score the chamber making the pump junk. If yours lasted as long as Pat's, $ per year it is not so bad.
