Subject: Re: Blum 90 degree FF Hinge?
6/30/17
Pat
Does Blum make a hinge like the Compact 33 that is limited to 90 degrees? If not, does someone else make a similar hinge that is limited to 90 degrees and will do 1 5/8" overlay and uses the same drilling as Blum?
Thanks,
Pat
6/30/17       #2: Blum 90 degree FF Hinge? ...
John Member
You can use an 86° restriction clip with the Blum Compact 39C series. It's available up to 1-9/16" overlay. Or the Compact 38B for 1-3/8"+ overlay; there's a 86° clip for that series, too.
John
7/1/17       #3: Blum 90 degree FF Hinge? ...
Pat
Thanks, John. Is the 1 3/8+ option the one that mounts to the face of the FF instead of the edge?
7/1/17       #4: Blum 90 degree FF Hinge? ...
John Member
Yes.
John
