Subject: Re: outdoor cabinets
outdoor cabinets
7/16/17
Travis
Guys-I have a good returning customer that has asked me to price outdoor cabinets for a deck area. I need the work, and hate to let down a loyal customer. Can anyone give me a heads up on material? I only have to build the boxes, no doors. And the customer plans on laying a rock veneer over them, tops included. I guess my main question is related to material. What would you suggest using for sheet stock?
7/16/17       #2: outdoor cabinets ...
Wyatt
King Starboard. It's about $250 a sheet and you have to use stainless steel screws but it'll last forever.
7/16/17       #3: outdoor cabinets ...
Starboard would be one of the more common materials. We use it where long term water is an issue. BUT it has to be mechanically fastened, SS screws and nothing much sticks to it so how would the stone veneer be fastened? It is a bit rubbery and flexible so heavy loading with a stone top might produce some long term bowing of the sides. Not enough to cause a problem with most cabinets but stone veneer and mortar joints may get some cracks.
7/16/17       #4: outdoor cabinets ...
Kip Stevens
My Hood Distribution rep showed me some thermally treated poplar and ash that is used for outdoor cabinets.
7/17/17       #5: outdoor cabinets ...
Tom
Website: http://tpgcabs.com
I built some using pressure treated plywood for the boxes and then put a solild color fence stain on the inside and used starboard doors .I used paver stones to create an 8" high kick to set the boxes on and to keep them above the snow and rain .
I did a poured concrete countertop with good sized overhangs and incorporated a drip edge [ just a simple kerf ] into the bottom of it to keep water from running back into the cabinets . I just used regular Blum euro hinges and while they got surface corrosion pretty quickly , after 13 years they still work .I believe there are ss hinges available .
7/17/17       #7: outdoor cabinets ...
Jim Member
I made a sign out of 3/4" MDO plywood 6 years ago and hung it on a chain link fence out by our dumpster. Exposed on all sides.
I have to go out and rework the message on it occasionally but the plywood looks like the day it was put out there.
7/17/17       #8: outdoor cabinets ...
Another vote for MDO if you need structural and dont want the cost of starboard. I have several pieces in full exposure for more than 10 years and the stuff still looks new.
7/18/17       #9: outdoor cabinets ...
Pdub Member
MDO is great, but doesn't always stay flat.
I sssume the starboard product is that PVC material? If so, that stuff is awesome. Expensive and "different" to work with though. Ours was pretty stiff and I'd trust it to hold up most loads. We made some boxes that got a 3" thick sandstone countertop on them and they're fine.
7/18/17       #10: outdoor cabinets ...
Harold
www.weatherstrong.com
7/19/17       #11: outdoor cabinets ...
Starboard is HDPE(high density polyethylene) Nothing sticks to it. #8 or #10 stainless self tappers are commonly used.
MDO is used for exterior signs. High quality exterior fir ply with paper faces. Paint it and it lasts forever. Cheap and looks good.
Marine plywood. They don't rot. Use it like cabinet ply. They build boats out of it.
7/19/17       #12: outdoor cabinets ...
Travis
Guys, thanks for the responses. I have decided to use 3/4" marine ply.
