Subject: Re: help buying a new edgebander
8/18/17
danny collier Member
looking at the Holzher 1327 and the SCM k560 both are servo. has anyone had issues with the servo motors? Any issues with the computer and or software? Is using the PUR glue worth it? Is one bander better than the other?
8/18/17       #2: help buying a new edgebander ...
bruce Member
we have the holzher 1329 and the scm k600 which both are a little over a year old.
we use the holzher with pur glue only as to apply laminate edgebanding since laminate can be troublesome to apply with eva glue without priming the laminate strips first .
we use the scm with eva glue to apply pvc edgebanding only.
Both machines have been great so far and we run them hard for 9 hours a day .
the scm works better for pvc banding and the holzher works better for laminate edges for us.
we've had no real issues with either machine .
What edges are you gonna apply or both?
8/19/17       #3: help buying a new edgebander ...
we will be doing mostly pvc and wood strips. verry little laminte. some 3m. have you used your holzher for pvc? you say the scm does a better job with pvc, but how much better as i am now more inclined to go with the holzher as i have had discussions with techs and owners of the holzher who swear by it.
8/20/17       #4: help buying a new edgebander ...
bruce Member
Concerning your thoughts on pur glue..since you be running very little laminate then I would stay with eva glue without a doubt. Pur glue and cleaner can get expensive and cost of labor and such for clean up ..
Yes we have and do run a little bit of pvc on the holzher and it does a great job.. What I meant was the way we run our shop.
Are you going with all servo motors on each station? Just make sure the tech goes over and gets you to totally and completly understand how to adjust each station with the on-screen menu.
If you go with a glue pot machine then bite the bullet and buy a extra glue pot.
I think you would be satisfied with either machine..
8/21/17       #5: help buying a new edgebander ...
to bruce..do you have any servo motors on either bander? my concern is the accuracy and future reliability of the servo motors as i hear they are very costly to replace
8/21/17       #6: help buying a new edgebander ...
bruce Member
jut 1 motor on our scmi which adjusts the pre-mill fence. everything else is manually adjusted . our holzher has quit a few as most stations are adjusted on screen.. we have had zero problems out of them. accuracy is great. where are u located?
8/25/21       #7: help buying a new edgebander ...
Ryan
Website: http://patzerwoodworking.com
We currently have a 6 year old Hozher 1336 Arcus and we run PUR on everything. We are 70/30 commerical to residential cabinetry and we found that the PUR made sense for us. We run 3mm and .018 PVC almost every day and have great success with it. We do try to buy 3mm FLEX banding as it has less memory than the rigid and gives the PUR time to cure. We have had several SCM banders and every once in a while we had issues with banding falling off and problems with the glue pots, so we decided to make the switch to Holzher entirely because of the PUR. Of course we have had our issues, but I haven't had 1 call in 6 years about a band falling off and thats a big deal when you are delivering product up to 6 hours away.
We just ordered a new 1556 Accura that will be here end of the year and they have made some nice changes.
6/22/23       #8: help buying a new edgebander ...
Allen Slotto Member
Our shop bought a k560 2 1/2 years ago. To be honest, we have fought with the adjustments ever since. At install, the tech literally said "I know what the numbers need to be, so I can't help you with that, you'll just need to play with it and figure it out". And yes, that was what he told us almost word for word. Finally, talking to a different tech who admits he isn't very familiar with the all servo machines, he told us how to get the machine adjusted properly. We spent 1 1/2 days getting it adjusted after that, cutters, scrapers, we had it set quite well, but then a crash a week later... If anyone can help, we think the crash has perhaps caused the top scraper to not be in position now, but we can't find any reference where to physically mount the scraper within range of the base setting for .5mm banding. 1mm and 3mm seem to be working properly, so we are confused why the scraper is not even close to the board with .5mm banding. I know, this isn't really an answer to your original question, but I mean it to be an insight to the need to force the tech to do his job and explain these adjustments. Our primary problem was that the tooling base setting was not within the adjustment range for the user profile. Now finally we are closer, but still again a little off
