Subject: Re: Low Profile hidden brackets??
9/8/17
Ben Clemmer
Website: https://www.houzz.com/pro/arkflint
Thanks in advance guys. Love the forum.
Longest time I've made "floating shelving" by creating a pocket in the shelf and make a hidden wood frame to attach to the wall. Standard fair. A more recent job is requiring me to make shelves that are 1 1/2"T X 10"D X 60" L. Do any of you guys have a source for a low profile metal bracket to deal with this? I'm thinking Hafele, but haven't had any time to invest in it just yet. Any quick words of advice would be great.
Thanks,
Ben
9/9/17       #3: Low Profile hidden brackets?? ...
Paul Miller
I think Hafele does make a bracket, but I do not have confidence in it. How much weight do you expect the shelves to have to hold?
If you visit my web-site, you will see a winery that we did and on the back bar wall, you will see shelves jutting out holding wine glasses. These shelves have no visible support. There is a mirror behind the shelf.
I had the Contractor put steel "L" brackets on the wall, behind the drywall. Actually, here there was no drywall because the mirror covered up the brackets. The brackets were 2" x 3/8" steel, bent on a 90 degree. I got these from a local welding shop. Make sure they are bent on a perfect 90. Sometimes they are not. I also had they drill and counter sink for screws. I have them drill and counter sink for screws on both legs. Make them universal if possible. We then made the shelves with a pocket and we slid the shelves onto the brackets. I have done this many times and it is safe and it works. I also do this for floating counter tops.
If you do this, one thing that I have found helps is to make up a temporary shelf and attach it to the brackets, it can be a piece of melamine and ask the contractor to mount the brackets with the shelf attached to the brackets. This way, the brackets will be level and the brackets will not be twisted.
I hope this helps.
9/9/17       #4: Low Profile hidden brackets?? ...
Richard
When we started doing floating shelves we did use the hafele hardware, its ok for light weight shelves.
https://www.hafele.com/INTERSHOP/web/WFS/Haefele-HAC-Site/en_US/-/USD/ViewProduct-
Start?SKU=000000dd00024a7d00020023
We now use shelfology. The hardware is heavy duty, but the back bracket is 1 1/2" thick.
Because of this we tend to use their "floating desk hardware", with this the bracket attaches to the side of the stud and is completely hidden.
9/9/17       #5: Low Profile hidden brackets?? ...
DS
Www.countertopbrackets.com
9/11/17       #6: Low Profile hidden brackets?? ...
Ben Clemmer
Thanks for all your responses guys!
