Subject: Re: Synching dust collector with chop saw
10/1/17
cabmaker
We have a few chopsaws scattered around our shop. One of the Dewalts has shop vacuum for the dust collector. Both the chopsaw and the vacuum are hooked into an electric switch that activates the vacuum whenever the chopsaw turns on. This is all fairly simple 110 power.
I am bringing a CTD chop saw online this week that is a 220volt machine. Ideally I would like to hook this up to a similar shop vac but am not exactly sure how to make the 110 vacuum start up when the 220 CTD turns on.
If I have to I could also hook up a 2 hp 220 volt dust collector to the CTD.
Does anybody know of a switch that could switch on a 110 device when a 220 device starts up?
10/1/17       #2: Synching dust collector with chop s ...
B
Just pigtail off one of the power legs to activate the vacuum, so it only gets 110v.
10/2/17       #3: Synching dust collector with chop s ...
I would hesitate to pigtail off one phase of the power.
We have found that the port on a larger miter saw (ours are Omga) do not work well with a shop vac.
We use a small collector and run a remote switch near the saw. They use it so it must not be too much work. If you are cutting a bunch just leave it on.
Bench top collector
10/2/17       #4: Synching dust collector with chop s ...
Wire up a 110v switch on the saw bench
10/2/17       #5: Synching dust collector with chop s ...
Matt M
Agreed with those saying to use a remote switch.
I wouldn't put an auto-start on a dust collector and miter saw, unless the "auto on" kept the dust collector running for at least 5 minutes or so. All the power cycles can't be good for the dust collector if it's just an instant on/off.
Our shop uses a remote control switch, but it's on a much larger 3 phase dust collector. There are remote switches available for 220v items that will work fine in your case.
10/2/17       #6: Synching dust collector with chop s ...
For shop vacs he is talking about a switch like the one in the link below. I bought a few for our Dewalt miter saw/shop vac setups years ago thinking that they would burn out quickly. Several years later they are still going. They keep the vac on for several seconds after the cut.
Auto on switch
10/2/17       #7: Synching dust collector with chop s ...
cabmaker
The switch Bill points to is exactly what I am looking for.
I too have a couple of these in my shop that have been in service for several years. They work great. There is a delay for the off setting to allow the vacuum to clear the hose. As I recall there is also a delay at the vacuum start up to minimize amperage requirements from starting up two machines.
What I am looking for is one of these that will interface with a 220 saw and a 110 vacuum.
As others have suggested we may try integrating a 110 circuit with the 220. This won't help with the extra amperage at start up but will make sure they are both operating simultaneously.
