Subject: Re: Gannomat line bore pneumatics issues
10/30/17
Peter Gagliardi Member
Hi all, I have a model year 1986 Gannomat dual line bore machine that has developed some pneumatic issues. I know nothing about it, but hoped someone might be able to help troubleshoot?
Anyway, the unit is operated by a 3 position rocker type footswitch. All the way back, and the work clamps retract. Center position, the clamps hold the work down. Forward, and the clamps are down, and the drill heads activate and cycle.
I lost a detent ball a while back for the clamp release position, but have been able to operate it anyway by just keeping my heel down.
The problem that just popped up is the drill head does not want to activate or cycle when pushing forward on it.
The back set of spindles always turn, but the front set is supposed to activate, along with the raise cycle when stepping forward, now nothing happens.
Any help greatly appreciated.
Thanks,
Peter
10/30/17       #2: Gannomat line bore pneumatics issue ...
Alan F. Member
Tritec support is pretty good, did you try them
TRITEC ASSOCIATES, INC
10/30/17       #3: Gannomat line bore pneumatics issue ...
I did not, as I had been told there was no support any longer in the US, but I will now, thank you.
10/30/17       #4: Gannomat line bore pneumatics issue ...
Bruce H
The first thing I would do is take the foot apart. I'd suspect dust inside interfering with the contacts. (done that to mine)
10/30/17       #5: Gannomat line bore pneumatics issue ...
L.W.
The valves in the pedal are sensitive to junk in the works that prevent good seals. I have a pin router that was not working right. I took apart the whole pneumatic system but I think the problem was in the pedal valves. I don't think I found the culprit blockage but when I put it back together it worked.
